82K views 265 replies 60 participants last post by  lyonstl
Since spending a little more time over here recently, I figure I'll add my car to the Members Ride section. I hope to be able to contribute as well as learn from the community to further push progress on this platform.
Current Mod List:
Engine
3.5L 6G74 - awaiting build
ARP Main Studs
Ported 6G74 Lower Intake Manifold
2G GS-T 3" Catback Exhaust
Diamante Throttle Body - Ported and Rebuilt with MIL spec shaft seals.
6G74 Fuel Rails
3SX -AN Fuel Rail Loop
Walbro 255 lph Fuel Pump
Fuelab FPR
Mishimoto Civic Half-Radiator
Catalytic Converter Delete
EGR System Delete
Evap System Delete
Prothane Motor Mount Inserts
Energy Motor Mount Roll Stop Inserts - with cross member bushings
Ingalls Stiffy ETD
482 MAF
Vibrant 4.5" MAF Adapter
DC Sports 4.5" Air Filter
Turbo
Holset HX35W - to be modified
SPE Custom Short Route Turbo Piping Kit
Treadstone TR1035 Intercooler
Manual Boost Controller
Tial 38mm Wastegate
Forge BOV
Transmission
F5M51 5-Speed Transmission
Wavetrac LSD
Motul Gear 300 75W-90
Speed Source Aluminum Shifter Base Bushings
Speed Source Brass Shift Linkage Bushings
Megan "Knock-off" Short Shifter
Greddy Counterweight Shift Knob
Spec Stage 4 Clutch - 6-Puck Unsprung
Fidanza Aluminum Flywheel
Suspension
Megan Racing Street Series Coilovers
3G Eclipse GT OEM Strut Bar
Prothane Lower Control Arm Bushings
Prothane Sway Bar Bushings - Front and Rear
Moog Sway Bar Endlinks - Front
Brakes
Full ABS Delete
Evo 8 Brembo Calipers - Front and Rear
StopTech Stainless Brake Lines - Front and Rear
Raybestos Severe Duty Rotors - Front
R1 Concepts Rotors - Rear
Hawk HPS Pads - Front
Raybestos Premium Pads - Rear
Wheels
Rota Boost - 17x8 ET +35
Hankook RS-3 245/40/17 - Front
Continental ContiPro 245/40/17 - Rear
Electronics and Lighting
6000K HID Headlight Bulbs
3000K HID Fog Light Bulbs
Sylvania Silverstar Turn Signals
Independent Fog Light Relay Wiring
Battery Relocated in Trunk
CompuSTAR 2W900FM-AS
Tactrix 2.0 OP Cable
Evoscan Datalogging Software
ECUflash Tuning Software
AEM UEGO Wideband
Prosport Oil Pressure Gauge
Prosport Vac/Boost Gauge
Audio
JVC AVX-33 CD/DVD Player
Pioneer 4-Way 6.5" Door Speakers
Pioneer 4-Way 6x9" Rear Speakers
Interior
SRS System Delete
A/C System Delete
Recaro Evo 9 MR Driver Seat
Silver-Painted Door Trim
OEM Carbon Twist Radio Bezel
OEM Carbon Twist Shifter Bezel
Glowshift 3 gauge single-din panel
3G Steering Wheel
JDM Chrome Interior Door Handles
3G Black Door Handle Trim
Carbon Fiber Instrument Cluster Bezel
Exterior
JDM VR-4 New-Style Bumper
JDM VR-4 New-Style Grille
JDM VR-4 New-Style Fog Lights
JDM 2-Piece Glass Headlights
JDM Pre-Facelift Tail Lights
OEM GTZ Spoiler
Color-Matched Keyless Trunk Garnish
Shaved Trunk Emblems
Carbon Fiber Mitsubishi Trunk Logo
EGR Rear Window Visor
January '07
The old powerplant. 6G72 with Automatic Trans.
The fun began April '10. Picked up the 6G75 with only 21k on it.
New timing belt and water pump of course.
Less than a month after getting the 75, out comes the 72.
2 days later, the first non-mivec 6G75 of the platform lives.
On the dyno at Car Craft
The Brembos were recently installed. Unfortunately after the cookout.
And finally, it's current state as of the All-Mitsu Cookout and Car Show
#2 ·
I like. Why you been hiding it all this time?:D
Looks great!!!
Great stuff.
Thanks guys! I don't know if it's really "hiding" that I've been doing. Staying low-key is more my style. I just figured I'd wait until I got to a point where it's worth sharing.
Silvertune is correct, the numbers are untuned. I have the tactrix 2.0 cable, but having the bastard child '99 ECU sucks. It appears to be flashable according to the test write in ECUflash, but I'll probably throw in the '01 ECU I have laying around since the ROM info is accessible.
Oh, Silvertune, whenever you want to do the clutch, I'll be around. I will be in my winter beater SHO since the tranny in the Galant went "Boom!" last week.
The 3 of us will have to meet up and do your clutch sometime. :lol:
So again, how difficult is the non MIVEC 6G75 swap? Looks like almost a direct drop in.
Using parts from the 74 and 72 it IS drop in, other than the obvious tune.
#17 ·
With the correct parts from different motors, it's a drop in. You need parts from a 72 and 74 to make it work.
M-Rod, what did you do about your shifter boot? Obviously the 3G boot doesn't work. Is the Integra boot the way to go?
#19 ·
looks great i like it! what did you do with the old engine? i don't remember seeing it up in the for sale?
neb, the old engine is just sitting in the garage. No idea really what to do with it. I've been waiting to find a 3G locally with a snapped t-belt for cheap and throw it in. Haven't come across one all summer so I'm not sure. I've been thinking about posting it on craigslist for $100 so I'm not sitting on it forever.
#21 ·
Info on the motor? :yesway: I'm not too far away.
